Rear Deck Removal
Old 09-11-2002, 01:19 AM
SmoothD's Avatar
Rear Deck Removal
Anyone know how to remove the rear deck (with the speakers on it)? If it's really complicated....don't worry about it, but I want to drop some DynaMat on that rear deck now that I have my sub in. Also, if anyone has advice on where I should focus putting the DynaMat in my trunk, I'd be very appreciative. I've only got a limited amount of the stuff and I want to make sure I've gotten the problematic spots covered before covering superfluous areas. Thanks Fellas.
Old 09-11-2002, 01:41 AM
ilike2cheez's Avatar
i would also like to know. I think the rear deck rattles the most. My trunk is fine.
Old 10-06-2002, 12:11 PM
SmoothD's Avatar
Somebody has to have done this before.
Old 10-06-2002, 12:34 PM
DamnThisHobby'sExpensive!
Acura3.0CL's Avatar
Yea i need to know BAD...i donno whats rattling (either the tunk or the back deck, but its BAD) i need to dynomat it bad....Wheres the best place to stop the rattles!?!
I know fosgate makes a dynomat substance in a spray can that works...also, i knwo if its your trunk lid rattling that you can lover the henge so it tightens the seal, (but then you screw with the trunk release)
Old 10-06-2002, 01:05 PM
The Human Radar Detector
jttoombs's Avatar
Dan was that your 2.2 that got into an accident on wester blvd?
Old 10-06-2002, 01:07 PM
SmoothD's Avatar
Yep...dammit.....get her back tomorrow.....Finally.
Old 10-06-2002, 01:20 PM
Trailblazer = SUCK
LCARUCA 97's Avatar
dynamat won't stop those rattles, if you want them to stop for good, do what i did and pull out the back deck, cut a peice of lightweigt wood the same size and cover it with autmotive carpet.
No more rattles. dynamat is only makes bass tighter and reduces road noise. plus its HELLA expensive.
Old 10-06-2002, 06:42 PM
DOOKS of hazard!!!!
d5c5b's Avatar
ok...cant help with the rear deck......but with dynamat...do not dynamat the rear deck....most of the sub noise comes through your deck,,,like someone said....remove it if youre worried bout rattle...and itll make you subs louder...dynamat it and itll block half your bass..dynamat the lid...ALL of it.....and dynamat the sides of your trunk....i wouldnt worry too much bout the floor....this is what i did and i have no rattles.......but beware.....the more you try to stop rattles the more rattles will appear.....so be smart...and maybe be prepared to buy more dynamat!
mada51589
05-03-2022 08:54 PM
02-25-2020 09:57 AM
HairyMonkey019
04-22-2016 10:50 PM
james357
02-13-2016 02:37 PM
Dunnik
09-15-2015 11:52 PM
Quick Reply: Rear Deck Removal
