Rear Deck Removal
Old Sep 11, 2002 | 01:19 AM
SmoothD's Avatar
Rear Deck Removal
Anyone know how to remove the rear deck (with the speakers on it)? If it's really complicated....don't worry about it, but I want to drop some DynaMat on that rear deck now that I have my sub in. Also, if anyone has advice on where I should focus putting the DynaMat in my trunk, I'd be very appreciative. I've only got a limited amount of the stuff and I want to make sure I've gotten the problematic spots covered before covering superfluous areas. Thanks Fellas.
Old Sep 11, 2002 | 01:41 AM
ilike2cheez's Avatar
i would also like to know. I think the rear deck rattles the most. My trunk is fine.
Old Oct 6, 2002 | 12:11 PM
SmoothD's Avatar
Somebody has to have done this before.
Old Oct 6, 2002 | 12:34 PM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
Yea i need to know BAD...i donno whats rattling (either the tunk or the back deck, but its BAD) i need to dynomat it bad....Wheres the best place to stop the rattles!?!
I know fosgate makes a dynomat substance in a spray can that works...also, i knwo if its your trunk lid rattling that you can lover the henge so it tightens the seal, (but then you screw with the trunk release)
Old Oct 6, 2002 | 01:05 PM
jttoombs's Avatar
The Human Radar Detector
Dan was that your 2.2 that got into an accident on wester blvd?
Old Oct 6, 2002 | 01:07 PM
SmoothD's Avatar
Yep...dammit.....get her back tomorrow.....Finally.
Old Oct 6, 2002 | 01:20 PM
LCARUCA 97's Avatar
Trailblazer = SUCK
dynamat won't stop those rattles, if you want them to stop for good, do what i did and pull out the back deck, cut a peice of lightweigt wood the same size and cover it with autmotive carpet.
No more rattles. dynamat is only makes bass tighter and reduces road noise. plus its HELLA expensive.
Old Oct 6, 2002 | 06:42 PM
d5c5b's Avatar
DOOKS of hazard!!!!
ok...cant help with the rear deck......but with dynamat...do not dynamat the rear deck....most of the sub noise comes through your deck,,,like someone said....remove it if youre worried bout rattle...and itll make you subs louder...dynamat it and itll block half your bass..dynamat the lid...ALL of it.....and dynamat the sides of your trunk....i wouldnt worry too much bout the floor....this is what i did and i have no rattles.......but beware.....the more you try to stop rattles the more rattles will appear.....so be smart...and maybe be prepared to buy more dynamat!
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
HairyMonkey019
Apr 22, 2016 10:50 PM
james357
Feb 13, 2016 02:37 PM
Dunnik
Sep 15, 2015 11:52 PM
