rear camber USING WASHER
sup guys.. it's been awhile since I logged in here.. anyways.. i know that there are some of you here have used "washers" to fix their camber problems in the rear.. can someone please tell me where to get these washers and how to install them.. a picture of the washer will be great... thanks
Originally Posted by shineynitelite
cant help you with the washer question but you HAVE to tell me where you got the CARBON FIBER much less TRIPPLE guage pod
unfortunately, mine didn't fit well
i don't know if mine is exact same as his.. but looks like his fits more better than mine
oh well..
Originally Posted by KLepTo
all you need is a longer automotive grade bolt and a bunch of washers to replace the stock one, the washers, push out the control arm, acting like a camber kit
I believe they remove the #61s and put the washers between #31 and the body, then put the #61s back in. Thsi pushes the rear upper control arm out forcing positive camber (reducing negative). Depending on how far out it needs to vome, longer bolts *might* be needed for #61.
i dont know how u reused the same bolt. even with one washer it was impossible. i had to use a 70mm bolt and two washers which were about 2mm each. im dropped 2" in the rear. i did post about this and what parts are needed. should come up in a seacrh.
Originally Posted by wilp99
is any one using lock tite or lock washers? if u dont then the washers WILL eventually loosten up the bolt. and.....well we all know what will happen.
nanos
Nov 12, 2015 08:41 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
