Random tech cat
Random tech cat
So I ordered a random tech cat converter to install in place of my old busted one. Finally got the bolts off after like 4 hours of prying and cutting and hammering and torquing the bolts... only to notice that the holes for the bolts don't line up on the header side (no it wasn't backwards, they don't line up any way you put it). We originally saw that instead of a 2 bolt connector the new cat had 3 bolts in the same triangle shape as on the rear of the cat but thought two of the bolts might line up. The other issue is that the piping on the exhaust and the cat are literally the same size, I can't really see any way that the cat will fit inside of the original exhaust piping.
Anyone installed one of these themselves that can shed some light on what I'm doing wrong? Maybe I got the wrong part?
Is this the way it's supposed to sit?
Here's the triangular bolt system on both ends
the new cat has 2 three bolt flanges while the stock one only has 2. thats your problem, you're either gonna have to cut it off n get a 2 bolt one or send it back and get the correct one.
edit: oh the cat also isn't long enough to fit if I took that section off
So I got the new catalytic converter and installed it. We took the spring bolts out from the front side of the catalytic converter (the bolts that were on the old cat) and just used regular hex bolts and nuts with a few washers. No exhaust leaks so it all sealed up good, but now whenever I take right turns or go over bumps or dips in the road I get this really loud knocking about where the cat is. Not when I take a left turn, only right. Ill get a video up of the noise when I get home (posting from phone)
Knocking seems to get worse as I've been driving longer which I'm assuming is due to the exhaust heating up more. Took a quick vid... you'll hear the sound towards the end of it.
http://s67.photobucket.com/albums/h2...t=MVI_5502.flv
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Eggs999bacon
09-24-2015 10:08 AM
