Quick question on installing guages.
on the RPM and speed meter, can I move the needle up to slide my guages in? because it is sitting at the needle stopper. Don't want to mess up the needle.. Thank you guyss..
Under it
There isn't a problem if you gently move the needle. Then you need to slide the hole in the gauge down the needle and then push it below the needle (The part that is attached to the needle) and you can get it around the small edge of the other end of the needle. I did this no problems...yesterday I put in an aluminum gauge bezel and it took me 15 minutes.
Skirmich
09-15-2015 06:41 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
