Quick Question
Old Apr 18, 2002 | 11:27 PM
hornyleprechaun's Avatar
Bent = #1
Quick Question
What is better to hook a sub up with...a lower ohm or a higher ohm....also what does ohm mean...thanks for your help...i know a bit about car audio just haven't figured out what ohm means...
CL'S
Old Apr 18, 2002 | 11:41 PM
CLUofI's Avatar
337
electrical resistance is measured in ohms, the lower the ohms the less the resistance. Realy low resistance can fry many electronics.
Old Apr 18, 2002 | 11:59 PM
93mikeaccord's Avatar
CL Owner Want-A-Be
Re: Quick Question
CL'S
CLUofI is exactly right. An ohm is the electrical resistance equal to that of a conductor in which current of one ampere is produced by a potencial of one volt across its terminals. Ohm doesn't stand for anything, it's names after George Ohms.
Check out the manufactor's specs on the sub-woofer. It should tell you exactly what you need. You can varry the from the required ohm slighly but you run the risk for frying your head unit. Some units come with a built-in a shut off for just just instances. Now my experience is with home electronics not car audio, so I would ask some at an install place or hopefully someone on the board has more experience than I do.
-Mike
Old Apr 19, 2002 | 12:05 AM
Bent = #1
Aight thanks for your help...
CL'S
Old Apr 19, 2002 | 10:16 AM
99CL2.3's Avatar
To add on what was said above, there are many factors involved here. Most car audio subs come in either 4 ohm or 8 ohm resistance. Then there are single and dual voice coil subs. You should also learn about series and parallel wiring. Without this basic knowledge, you can do serious damage to your system and possibly your car.
Old Apr 19, 2002 | 10:55 AM
Casper98CL's Avatar
You Fawkin Kiddin Me!
It depends on the sub ability.. my subs run at 2 ohm with 1 ohm capabilities.... do research on YOUR product!
Old Apr 19, 2002 | 11:20 AM
99CL2.3's Avatar
It really depends on the amp's ability actually. If you try to run a cheap amp at 1 ohm, you're in for a surprise. I've never heard of subs that have varying resistance. What kind of subs you got?
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
06TLMatt
Oct 2, 2015 08:14 PM
Strath
Sep 27, 2015 11:53 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
datadr
Sep 12, 2015 09:12 PM
