Questions on Installing Clear corner turn signals on a 97 cl!
Old 08-07-2003 | 05:25 AM
ashegam's Avatar
5th Gear
I'm surprising a friend by borowing his car and installing these clear corners. Since these lights are on the bumber how do I take them off? Can it be done by popping the hood or do I need to do it from under the car? I just need to know if this is something I can do my self as I have a good amount of tools and have done this sort of thing on other cars.
Old 08-07-2003 | 11:08 AM
dustbuster4's Avatar
A-CL Post Whore w/N2O
All you need to do is to loosen the single screw that holds the lense securely to the bumper. The other end of the lense is spring-loaded and will pop out. Twist out each of the light sockets, and remove the lense. Make sure to remove the spring from the OEM lense and mount it on the new clear lense. also remove the screw guide and screw from the OEM lense and mount it on the new clear lense. Twist the light sockects into the clear lense and remount the lense to the bumper.
The arrowheads indicate where you'll find the 2 screws.
Old 08-07-2003 | 12:24 PM
ashegam's Avatar
5th Gear
fabulous, thanks bud.
mada51589
05-03-2022 09:54 PM
theinsvnity
09-10-2015 11:22 PM
HOWELLiNC
09-05-2015 04:09 AM
voigt
09-02-2015 11:44 PM
ptbarnett
3G RLX (2013+)
08-30-2015 01:39 PM
Quick Reply: Questions on Installing Clear corner turn signals on a 97 cl!
