Questions On 99 2.3 Header.
Man im stuck, im not clearly sure on which Header to buy. I need a new one ASAP due to my intake manafold is cracked. But Which to buy.... 97 Accord F22 model or 98-02 F23 Model. Iv heard many things. But I want to get it right the first time due to that im buying online. Anyone got a clear answer? Possibly someone with an updated header and same model and year. Car is a 99 2.3 (F23a1 motor)
Aight, I just want to be safer then sorrier you know. Cause Iv read a few things about how a 97 accord coupe exhost system would fit the car, not sure what all it included, and iv also read that some people have put 97 Accord race headers on there 99 2.3 CL, so I just wanted to make a last minute security question, I ordered the header like 3 days ago but just wanted to be sure you know.But thanks alot man.
Originally Posted by F23CL757
Thankx man, just one of those things that I need ASAP, so I went with my gut and I suppose I got the right one, but thankx man.
Originally Posted by VXCL
to sum up what i mean real easy.
94-97 accord ex dc 4-2-1 cc header hhc5017 will bolt on perfect and the down pipe bolts up to small section of pipe between the cat and the down pipe. (this section is where the o2 sensor is on a 97 2.2cl or accord ex)
98+ 2.3cl and accord I4 dc cc header hhc5018 will also bolt up perfectly. its down pipe bolts up to the cat and has the small section of pipe that is seperate on my 97cl. where the 02 sensor goes is beyond me. im not 100% if its down there or not.
EASY way to figure out what u need. look under ur car and look at the down pipe of the stock header. does it bolt directlt to ur CAT??? if so get the 98 hhc5018. it will be bolted with 3 bolts in a triangle pattern. if not and it bolts to a small section of pipe before the cat that has the o2 sensor sticking out of it. buy the 97 hhc5017. it will be bolted together with 2 bolts across from each other.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Sleep_DEPRIVED_Sleeper
your intake manifold is cracked? then why are you buying header? unless you meant exhaust manifold...
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
