Question about flywheels
Old May 15, 2006 | 09:53 PM
Wannarace62188's Avatar
We ride RIMS!!!
I am replacing my clutch in a few weeks.. I am looking at an Exedy Stage 1 right now.. When i do my clutch i am also doing the slave cylinder and the flywheel. I want to go with a light weight flywheel as i have plans for this motor. My question is what does the stock flywheel weigh and what lb flywheel would you suggest. I found 12.5, 8.8, 8, and 7.5. Let me know
Old May 15, 2006 | 11:07 PM
xrunner86x's Avatar
A-CL Totaled Member
The stock flywheel is about 20lbs. Id go with the 12.5. You don't want to go too light because the lighter the flywheel is, the faster the rpms drop when you shift.
Old May 15, 2006 | 11:50 PM
SwervinCL's Avatar
Nom Nom Nom Nom
that would be good for solo 2, no?
Old May 16, 2006 | 12:13 AM
xrunner86x's Avatar
A-CL Totaled Member
Sorry, but what is the question?
Old May 16, 2006 | 12:54 AM
SupraManAG's Avatar
One custom CL
not too light, not too heavy
10-12 should be good
id go with the act chrome-moly forgings instead of the Exedy aluminum. Your choice.
Old May 16, 2006 | 12:57 AM
xrunner86x's Avatar
A-CL Totaled Member
Aluminum is fine for normal use, but im tearin mine up with boost (been resurfaced once and ive only put 20k on it). Id second this recommendation.
Old May 16, 2006 | 12:58 AM
SupraManAG's Avatar
One custom CL
if im not mistaken you can chage the aluminum on yours
hows the car running man?
Old May 16, 2006 | 01:03 AM
xrunner86x's Avatar
A-CL Totaled Member
I mean the aluminum flywheel isnt causing a problem as of yet, but they did resurface it when i went from F23 to H22. I know the clutch i have now is only rated for 275 ft-lbs and im putting over 300 to the wheels, so im tearin that up for sure. Other than that, its running great now that I got it built. I got a couple videos tonight that are awaiting google approval, then i'll post them up, and now that its summer and im out of school and got a new digicam there will be plenty more to come.
Old May 16, 2006 | 01:27 AM
shineynitelite's Avatar
NAWWWWSSSSSS
^ i sent you a message homie
i have a fidanza flywheel, so does clman nothing but good stuff from ours
Old May 16, 2006 | 01:29 AM
SupraManAG's Avatar
One custom CL
for sure
im looking to buy a blown h22 with intact block
tear it apart and take it to the machine shop down the block for the work
it will take a lil longer but im sure it will cost a lot less money
did you run into any issues with the turbo piping?
Old May 16, 2006 | 01:49 AM
xrunner86x's Avatar
A-CL Totaled Member
for sure
Nope, doooooooo it.
Old May 16, 2006 | 11:46 AM
teh CL's Avatar
im lookin into one too...my clutch is goin in soon and i rather put a lightweight flywheel in rather than resurfacing the stock one
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
DerrickW
Nov 15, 2015 05:52 PM
