Question about Ebay Intake
well i juss got a ebay intake and i was wondering if a MAF adaptor or wuhever is needed? or would my car b ok without it. feedback would be appreciated thank you
...is now Carbon Fiber'd
The CL has no MAF sensor, it uses the manifold pressure/vacuum (MAP sensor, manifold absolute pressure) and manifold air temperature (MAT or IAT depending who you talk to) and through the use of the ideal gas law you can derive density. Since the volume does change and you know density, the load can be determined and the needed fuel can be calculated.
nerd
and for a short answer there is no hookup for the maf sensor. our cars dont have one. go for the ebay intake, but make sure you spray it with k&n oil..
what exactly does the oil do?
what happens if you dont use it?
Nothing really, you'll just wear out your crappy ebay cotton filter quicker, the K&N oil makes more dirt and stuff stick to it
i had a crappy ebay intake for 2 years and never had a problem with it. i cleaned the filter every 2 mos or so.. with the k&n recharge kit, and off i went. every time i cleaned it, it looked brand new. and yes you use the soap it comes with then water out of the hose. gluck pimp.
i plan to buy an ebay cold air intake for my tl-s as soon as i get back from this airshow trip to spangalam, germany.
ok on that pipe does any one kno wuh the real small nipple hole(upper left corner) or wuh every the fuck u call it is connected too? i tried installing it today buh i got relli confused to where it hooked up 2 so i ended up putting the air box in. well help will be appreciated thanks.
sorry about this... buh one last question and a let this thread die. what did u guys use to mount an ebay intake? i searched buh i onli could fine one and he drilled and welded. im not really up to that. any ideas?
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
