Question
Old Oct 5, 2004 | 02:08 PM
97-3.0Man's Avatar
CL Champ In Training
Question
Does anyone know of any place in wich I can run a wire through the firewall on either side, If not then a place that is safe to drill cuase atm I got 7 wires zip tied under the car and they are pretty exposed
Old Oct 5, 2004 | 02:11 PM
Hobo's Avatar
Flap.
above the gas pedal and towards the door there are a few circular indents i pulled a 0 awg through there, so theres plenty of room, a step bit will make quick work of it...
Old Oct 5, 2004 | 02:12 PM
97-3.0Man's Avatar
K Ill check it out thanks man
97-3.0Man's Avatar
are there any one the passenger side?
Old Oct 5, 2004 | 02:36 PM
Hobo's Avatar
Flap.
i didnt check over there, the battery is on the drivers side so why would you want to run across the engien bay?
Old Oct 5, 2004 | 04:35 PM
wilp99's Avatar
some times u need to run it across the engine compartment, cause if u run the power wire on the same side as the speaker wires both rca and hi/op u will get engine noise.
Old Oct 5, 2004 | 08:43 PM
Hobo's Avatar
Flap.
i ran the signal cable down the other side, it is easier to re run signal/speaker cable than to drill a hole in the fw
Old Oct 5, 2004 | 08:57 PM
fizzle's Avatar
Well, I dunno...
Thats where I went with my 0 gauge too...
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
