Question
CL Champ In Training
Question
Does anyone know of any place in wich I can run a wire through the firewall on either side, If not then a place that is safe to drill cuase atm I got 7 wires zip tied under the car and they are pretty exposed
Flap.
above the gas pedal and towards the door there are a few circular indents i pulled a 0 awg through there, so theres plenty of room, a step bit will make quick work of it...
some times u need to run it across the engine compartment, cause if u run the power wire on the same side as the speaker wires both rca and hi/op u will get engine noise.
Flap.
i ran the signal cable down the other side, it is easier to re run signal/speaker cable than to drill a hole in the fw
Well, I dunno...
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
