Putting in new radiator Help!!!
Old 09-23-2003 | 06:28 PM
19972.2cl's Avatar
I have a 1997 Acura CL 2.2 with 149,000 miles and I need help putting in the radiator. Any help would be appreciated. Thanks
Old 09-23-2003 | 09:25 PM
d5c5b's Avatar
DOOKS of hazard!!!!
bro, just look in your engine bay.....this is easy shit.theres a couple hoses bolted to it, prolly just use a flat head screw driver and unscrew em and take em off... be prepared for fluid to come pouring out. then once all the hoses are off, theres like 2 bolts holding it up on top...and i dont believe theres any bolts in the bottom...it has like hese little nobs that just sit in these holes......anyway, pull it out.....replace with the new one and then when you refil the fluid.....fill all the way up, then wait a minute......squeez the hoses as if you were pumping them.....so to move the fluid into the engine....youll see the fluid level drop, then fill again and do the pumping again.....bla bla bla......and once it seems full full then cap it.....run the car for a mintue....and check the level again.........do your best to keep it full to the top and youre good! have fun!
SidhuSaaB
05-30-2020 01:40 AM
pistacio
09-26-2015 10:45 AM
Matthew Purpura
09-25-2015 07:10 PM
Dman00tl
2G TL Photograph Gallery
09-25-2015 11:34 AM
STL TL-S
09-23-2015 09:52 PM
Quick Reply: Putting in new radiator Help!!!
