Problems With Window Reg. Install
Ok i installed the window reg. it goes down fine but does not go up at all.and on the window switch when u press it down it goes up and press up it goes down!! any info!!
Originally Posted by Dicorp
that wat i did follow..i guess ill re go over it!
it might be a faulty regulator, i had this on my prelude. it would go down but not up because the gear in the motor was worn out, couldn't handle the weight of the window. i have no personal experience with cl regulators,i have no idea how they work. the only one i changed was done by a shop, back when i had no idea how to do anything on my car.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Either the reg is bad or it's not in the track correctly
Nom Nom Nom Nom
No, its not a bad reg. Its probably a reg. for an accord. The wiring is backwards. Cut the wires coming from the regulator to the switch and reverse them. Thats what I did with mine. Why it does not go back up, I dont know.
cycdaniel
12-17-2019 10:58 AM
TLDude876
12-28-2016 03:18 PM
ahsm
09-09-2015 08:35 AM
asahrts
09-04-2015 05:55 PM
