problem with my shock sensor
Gimmie my points Biatch!
So i followed will99 diagram. The door unlock and locks with the chirp. But when I shake it the led light blinks so I know there is power to it. But i lost the ability to have the alarm go off when the doors are open, and plus the shock sensor doesn't work. I checked all the connections and they are all good. I have the blue wire attached to the hood latch which is the light green wire. I am damn annoyed.
i ended up having to hook it up to the door switch wire on the same harness. ill take a pic of mine and shoot it to u. tho i still dont have the lock chirp. i do have the unlock chirp tho. i think since the doors uperate the dome light that is why u dont have any action from hooking it up to the hood. if there was a way to open the hood with it armed then im sure it would go off.
heres some pics. urs may be different colors but thier all in the same pin positions
http://pg.photos.yahoo.com/ph/wilp99/album?.dir=/fbbf
red goes with white w/grey dots, black goes with black with grey dots, and blue goes with turquoise w/black stripe and grey dots.
heres a new pinout of where mine is.
http://pg.photos.yahoo.com/ph/wilp99...49.jpg&.src=ph
MUTHERFUKER!!! oh well, i guess a search is always not the best option! I was using the old diagram. I probably give it try tom or next weekend. If tat bitch don't work i guess i come back and see what it can be.
i really dont understand it my self, cause if u try to lock the doors with the door open it cherps three times still. so it doesent think the door is still open.
diode huh, lets try it.
Red -> +12V
Yellow -> Ground
Blue -> Goes to Green/Black wire on "Security Control Unit"
Green -> Pre Warn (Not Currently Hooked Up)
From that is what they did. They didn't have a nice chart like yours so they have to only do it by wire color. That must have been a bitch for them. From the DEI directions (they edited for their wires) you need a diode if you don't use the warning. You don't need a diode if you use all 4. There was a couple of people that didn't use the diode and it gave them werid problems. I hope this is the reason Y we experiencing this problem. Damn 75 cent part.
Originally Posted by wakeboardfusion
when is someone gunna try this
WAYFASTWHITEY
I'm doin it thursday night. the line on the diode shows where the cathode(negative) side is. It's used to allow voltage to travel only in one direction. Are you guys taping into the door trigger?
WAYFASTWHITEY
let me know what happens. I wanna get it right the first time. I don't have any time to install mobile electronics out of work, and thursday is the only day we're not booked up.
well grounding it to the chassy doesent help at all. it still works as a shock sensor so u could wire it to the chassy for easier installation. looks like a trip to radio shack. what are the specs on the diode required?
how many volts is the diode
I am sorry that some of u going to be a test dummy for this till good weather comes for me. It raining like noahs coming here today.
so u have to do all that to make it chirp at the lock or does it chirp all the time?
ok now my shock sensor doesnt work at all, and my alarm keeps randomly going off
Miss th 3.0
ok so now my sensor is fucking up again, the lights flash and go on and off randomly...whats wrong? when i unplug it from power its fine for a few hours, but then it fucks up again
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
09-17-2015 09:01 PM
