is it possible
DJ MSR NRG!!
is it possible
hey guys is there a way i can find out which h22 motor i have by the engine number i know i have the h22a but how can i find the year and ecaxtly which one it is . is it si ? si-r ? rev limit horsepower ? please help
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Search on here, Matt has posted the info on here
To find the year it was made, look on the exhaust side of the head. There will be 3 separate stamps. The middle one should have the numbers 1 through 12 in a circle with an arrow in the middle pointing to one of the numbers. That's the month it was made. On both sides of the arrow there will be 2 larger numbers which indicate the year.
I know it isn't an SI-R, I believe its a standard 96 JDM H22a, 200hp and 153tq at the crank. A dyno tune would be greatly beneficial for that car though.
DJ MSR NRG!!
ima try to find the stamp tommrow for the dyno that i will do once i do the water pump and timing belt fuel pressure regulator new MAF thermostat coolant flush all before the winter !!
DJ MSR NRG!!
well as old as it is it still runs like a champ
getting a new clutch n flywheel next week
susspension is almost done
changed starter alternator battery
tommrow all the ground wires terminals
the engine ground was shorting out the car mabe u have noticed that it would blow fueses all the time
gettin new head lights soon
and the paint
what kind of fuses were you blowing? i sanded down the terminal on the engine ground a few times and replaced the bolt. i never really had a problem blowing fuses.
did you figure out why the climate control isnt going on? i searched for a busted fuse and couldnt find one.
the starter and alternator was something i was gonna replace around this time had i still kept the car.
DJ MSR NRG!!
other then that its time for a new clutch pretty soon
whole suspension is done and all the electrical componets
trying to find a power steering assmbly too
I'd look into the 4th gen Accord and see if the base model had a manual steering rack. It will make turning the wheel so much easier and you won't lose those few horses from the motor turning that extra belt.
I can't image driving the CL with a power steering rack and no power steering. I did it with my Civic and it's hell to turn when you're sitting still. The CL is almost a 1000 lbs heavier.
