Poping sound
Everybody Wang Chung
Poping sound
I noticed this popping sound that happens when I turn the wheel all the way to the left. Has anybody experienced this also?
Nope the only thing that happens when I turn my wheel to the left is that when I'm trying to increase the volume, the stations will change! But that's another topic...
You Fawkin Kiddin Me!
maui.. dont be bitter at all.. I got same problem as melo.. IT SUCKS....
woodsdaddy.... stupid question but did you check steering fluid? what about your inner wheel well, may be loose... or check your ball joint bushing and boot....
Originally posted by Kiljaedoen:
<STRONG>if its a speed related sound it coulf\d be the cv joint</STRONG>
well fortunately well over the 30,000 mark and no problems for me..(knocking on wood) thank god.... yea defintely get it checked out asap....
First Gen PRINCESS
I tried to listen for that sound the other day and nothing yet (knock on wood). I don't have anywhere near 30,000 miles yet so let's all pray that it doesn't happen then.
Bye Bye CL!!!
sorry to bring back an old thread but I am having the exact same problem and it's only when I turn left. This is the only thread I found that would be of any help but it wasn't...so is it the ball joints?
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by starboy2nv
turn the wheel full and take a look, if you see a tear or mad grease all over the place, then its the boot!
for a second there, i thought casper came back...
Bye Bye CL!!!
I was just under the car not too long ago changing my oil and I didn't see any tears on my CV boot or grease anywhere. I changed the cv boot on my lexus 2 yrs back and it's not the same ticking sound that my lex made. It'll tick once after 1/2 rotation and then it'll tick again on another 1/2 rotation. I'll go check it out again though.
any input would be greatly appreciated
Bye Bye CL!!!
The boots are fine... My question is considering it is the ball joints how much am I looking at spending? is it hard to do? any recalls on them? has anyone else had this problem?
after searching the forums someone posted a recall list but my car doesn't fall under that list of vin's.
(Mid-Atlantic)
(Mid-Atlantic)
Do u have a link to that recall list? I need to see if mine is under it
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
Woody, I have the same thing, I also have it when moving slowly from a stop. I've checked everything multiple times. I've replaced both axles, tightened up everything, replace numerous bushings, etc.
There are a few of us here who actually have it
Nom Nom Nom Nom
Thats odd. From the description i would have thought for sure that it was the CV's.... The outers ones(next to your tire) rip and all the grease splatters all over your rim then eventually it will dry up and you hear them clanking together when you turn the wheel and go around a turn.
Is it like a click, click, click, click...Like a constant click until you are going straight or is it a just like 2 or 3 cluncks?
That's what I would of assumed as well. It's more of a "POP" then anything for me. I've even been so bothered i've taken it to Acura 2x's, had 3 or 4 different friends at shops look at it as well.
how handsome I am
DA BOOOT
Originally Posted by 972xghost
whatttttt how is this possible. how do some of you lucky bastards have barely 50K with 97's!!!!!! by the way nice mod list.
that was back in 2001 car prolly has 132198746912359085 miles on it now.
Bye Bye CL!!!
3.5RL
Beginning VIN Ending VIN
1996 ALL
1997 ALL
1998 JH4KA...WC000001 JH4KA...WC007053
2.5TL
1996 JH4UA2...TC021065 JH4UA2...TC025075
1997 ALL
1998 JH4UA2...WC000001 JH4UA2...WC006036
3.2TL
1996 JH4UA3...TC012319 JH4UA3...TC014540
1997 ALL
1998 JH4UA3...WC000001 JH4UA3...WC008112
2.2CL/2.3CL
1997 19UYA1...VL023878 19UYA1...VL023878
19UYA1...VL024293 19UYA1...VL024652
1998 19UYA3...WL000001 19UYA3...WL000022
3.0CL
1997 19UYA2...VL018057 19UYA2...VL018057
19UYA2...VL018439 19UYA2...VL019398
19UYA2...VL019402 19UYA2...VL019402
1998 19UYA2...WL000001 19UYA2...WL000013
What is the reason for this notice?
Honda Motor Co., Ltd. has determined that a defect relating to motor vehicle safety exists in certain Acura automobiles. Some vehicles were manufactured with front suspension lower ball joints tht may prematurely wear out. In the worst case, the ball joint would separate without prior warning, causing the front suspension to collapse. The condition would result in vehicle deceleration and a sudden loss of power. Also, steering controllability would be reduced, and a vehicle crash could occur.
What should you do?
Call any authorized Acura automobile dealer and make an appointment to have your vehicle repaired. They will replace the front lower ball joints. This repair will be done free of charge. Parts are now available. The repair takes about two hours, but please plan to leave your vehicle at the dealer all day to allow them scheduling flexibility.
Bye Bye CL!!!
I know what your saying about the constant clicking with a ripped boot...but it's more like 2 or 3 pops when I turn left even if I'm not moving. My outer boot is fine it has no rips or tears I don't see any grease splatters anywhere.
(Mid-Atlantic)
(Mid-Atlantic)
Thanks for the list JayT, i think i'm part of taht, i will check tonight
Bye Bye CL!!!
but your wheel is still turning. Its still gonna cause your cv to move. I think you have a bad axel to begin with.
I can always come take a look at it sicne your local.
Bye Bye CL!!!
I more or less feel it in the steering wheel hard to tell. I was trying to have my sister turn the wheel while I listen from the outside but I couldn't hear a damn thing. I need some one to drive the car while I listen from the outside, but she can't drive stick... swervin are u busy today?
Bye Bye CL!!!
Ah, if you feel it in your steering wheel that really sounds like it could be your steering rack. I am busy after work unfortunatly. What do you work this weekend?
