Plugs & Wires
Old Jun 10, 2004 | 05:50 PM
AdamsNew98CL's Avatar
IM RICK JAMES !!!
Plugs & Wires
Im getting ready to do a tune up and want to get the best stuff. I was thinking Bosh 4 Platinum for plugs (Anyone know if there is a gap?), a K&N Air Filter, but i was wondering what are prob the best plug wires to go with, and is there any difference in distributor caps, and finally the best fuel filter to use. Thanks in advance, oh and for those of you who looked at my pics before, I just got the PS2 hooked up, ill get some more pics up shortly
Old Jun 10, 2004 | 06:26 PM
HyDrOpOnIkToKa's Avatar
HOOK EM HORNS
bosch +4 come with a factory set gap,, im currently using them,, i just ordered denso iridium plugs to replace my bosch with
i use NGK wires
stock fuel filter
Old Jun 10, 2004 | 10:45 PM
97Black2.2CL's Avatar
got audio?
i hear the bosch platinums aren't really that good. i would go with the densos too. and NGK plugs will do a fine job
Old Jun 10, 2004 | 10:51 PM
ju5tchi11in's Avatar
roomate has a CL too
NGK is good or get some OBX 10.3mm
Old Jun 10, 2004 | 11:00 PM
xrunner86x's Avatar
A-CL Totaled Member
OEM = NGK, I'd stick with them. Gap should be in the manual.
As for aftermarket wires, you will not notice a difference between them, they are all about the same. If you want blue or yellow this is an awesome deal. I got mine back when they still had red. Nobody makes an aftermarket distributor cap for the 2.3, so you're stuck with stock, which is perfectly fine.
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
