please help me!!!!
please help me!!!!
hey guys so i got a 99 cl spindle for my 97 (knuckle,hubassembly and rotor togther,the whole thing) is it GOING TO FIT ON MY 97 CUZ THE DAM ROTOR LOOKS SMALLER............................... and is it gonna cause a problem if my driver side is old design?
thanks
thanks
well i mean spindle as in knuckle,bearing,hub,and rotor the whole piece
ok so heres what i did i changed the brake brackets and calipers with the 3.0 design but now i need to change the rotor to the 3.0 design.the brakes are not sitting right on that smaller rotor so can i just swap in the bigger 3.0 one?
please tell me thats possible
yes its bigger but the lug sizes are the same , and the spacing is outwards and to the top not towards the bottom where the hub is correct?
if 3.0 rotors cant fit on the 2.3 hub what will happen once i put them on the lugs?? ............didnt some cl'er on azine interchange his 2.3 with 3.0 rotors and calipers and brackets?.. that is without changing the hub..
i just ordered me a 3.0 rotor can someone please confirm that it will sit on the 2.3 hub?
(i understand that the dust shield would have to be moved out of the way for the longer rotor)
read the noob guide. the legend caliper swap has been explained many times.
how hard was removing the axle nuts and the old hubs and spindles? Did you need any bolts or were you missing any other parts aside from moving the 3.0 plastic shields over?
oh no no i think ur getting the wrong idea, heres what i did.
the axle nut is easy to remove..really easy just bought an 18'' breaker bar for 20 buks and loaned the 36mm socket and popped right off with tire on the ground
then i removed my 1997 3.0 knuckle (its failed thats why im doing all this)
bought a 1999 2.3 spindle( with the whole knuckle bearing hub and 2.3 rotor installed)
removed the 2.3 caliper and brake bracket
took my old caliper and brake bracket and put it onto the 2.3 spindle(knucklebearinghubrotor unit)
then i put that onto my 97 3.0
i ordered a 3.0 rotor to fit onto the 2.3 hub cuz obviosuly the bigger brakes i have on are now extended beyond the surface of the rotor
im plannin on installing that (the rotor) this friday cuz auto parts store dont have it in stock
as far as removing the knuckle ,remove the tie rod connection with the knuckle, open the lower ball joint; jack up the rotor ,and put a wrench or whatever metal between the knuckle and the control arm THEN SLOWLY release the rotor down from the jack , the control arm now being unbolted through the ball joint has no where to go but DOWN
then just unbolt the upper ball joint and take that off
dont forgot the abs and brake line
Man I need to put my legend calipers on
so the legend calipers front and rear fit the cl .92-96 Prelude VTEC rotors biger than the cls. so get a set of legend calipers and order a set od prelude VETC rotors thats it right,do i need any thing alse
