Please Help!!! Cruise Control?????
My bolonga has a 1st name
PLEASE TAKE THE TIME OUT TO READ/REPLY!!
Hey guys I need some help. My cruise control stopped working. It has been this way for a while now and I jus been too lazy to get around to it. The little green light on the button itself doesn't light up; neither does the light in the instrument cluster when the 'set accel' button is pressed.
When my head lights (or parking lights) are on; the lights on either the button or cluster work and the car does not keep constant speed when set accel button is pressed.
When my head lights are totally in the off position; the light on the button still does not work but the light in the instrument cluster will turn on and constant speed will be kept when the 'set accel' button is pressed.
Whats going on here? Why the hell does the lights have an affect on my cruse control?? I was thinking it was something i did when i installed my indiglo's cuz i hooked the indiglos up to the stock dimmer switch. But i've had this problem with the cruise about a month before i even got my indiglos.
Please help ASAP guys; I'm goin on a trip in about a week and I'm gonna be in despirate need of cruse control if i'm gonna keep myself outta trouble.
Thanx again; and please help once again.
I tried that but when i looked at the panels for what each fuse is for; i didn't see anything that relates to cruse control in either of the two fuse boxes.
Please help me out here guys...
97AcuraCL...
I'm in the same boat as you....somewhere between installing my CAI in february and now my Cruise Control stopped working. The CC light comes on, but i can't set a constant speed at all....what happened to our Cruise Controls!!!
i know someone on this board knows; just too lazy to read my whole post. but i wont give up on this topic till i get some info i can actually use; someone please help ASAP
this happened to me. this is what happened with mine:
the plastic spool type thing that catches the cable for the cruise control was broken. i had to get a whole new throttle body assembly.
all the lights would come on and stuff, it just wouldn't set.
hmm maybe u guys disconnected someting while installing ur intakes. I have an AEM also . i need to check and see if my criuse works. I barely use it so i need to check it out. Never thought about that,
Pull it out
Try pulling out the cruise control. Put a small flat screw driver in the small opening at the bottom and pry it out. Put some tissue over the blade of the screw driver so you don't scrape. You could see if anything is disconnected behind there or cut. Or it may not reveal anything at all...just a thought.
This might sound crazy, but my cruise control stopped working because of a burned out tail light. Check all three rear lights and check the running/brake lights as well.
The indicator on the dash didn't say I had a burned bulb, but I did.
Works now!
Works now!
Below are the electrical wiring diagrams for your cruise control from the Electrical Troubleshooting Manual. You should be able to identify the bnad component or problem from these.
[IMG]C:\Dnload\New Folder\CruiseControl1a.jpg[/IMG]
[IMG]C:\Dnload\New Folder\CruiseControl2a.jpg[/IMG]
[IMG]C:\Dnload\New Folder\CruiseControl3a.jpg[/IMG]
[IMG]C:\Dnload\New Folder\CruiseControl4a.jpg[/IMG]
[IMG]C:\Dnload\New Folder\CruiseControl5a.jpg[/IMG]
Well 97AcuraCL, I tried to give you some help but your sarcasm about the jpg's not posting right is just too overwhelming. A suggestion on how I should have done it differently might have been much more productive.
Although I also saved the same pictures in a single pdf file, I think I will avoid trying to post it as I want to avoid more sarcasm if it does not post right. I suggest next time you be a little more gracious when someone puts out some effort to scan five pages and help you.
Here are the 13 pages of the 1997-98 Acura 3.0CL Service Manual. I hope they help.
[Click on "Get Original Uploaded Photo" for a larger pic.]
BTW: I need to delete these pics in about a week. I'm running low on available storage on my Fotki site. Print them if you want them.
[Click on "Get Original Uploaded Photo" for a larger pic.]BTW: I need to delete these pics in about a week. I'm running low on available storage on my Fotki site. Print them if you want them.
hey guys thanx for alll your help i know u didn't have to do that. and dust i printed all of the things out so u can delete if u'd like to now. i do apprecaite thing is i'm not very technically minded and therefore dont know if i can tackle this on my own. I might have to make a trip to the dealer. just the thing is with my indiglos installed i dont know if they'd be willing to even touch the car. Its warantee is long gone but i dont know if they'd be willing to touch it even though i'd be willing to pay (sicne it seems i dont have a choice)
anyway; thanx again guys. precaite the help and RhoXS; i apologzie once again for my rudeness. ur okie in my book and ocne again i appreciate ur help.
Take a look at the electrical wiring on page 34-2. Notice that the "Cruise Control Indicator Light" in the cluster is connected directly to the dimming circuit. This module causes the instrument lights to dim when the headlights are on. This is the only connection with the headlights that I can see.
Although it is a royal pain to pull the instrument cluster, try removing this bulb and see what happens. If the symptoms you describe change, then you have found the area to focus on.
I do not know how the cruise control is effected by this indicating circuit but, based on your description of the problem, this is the only suspicious area I can see. If the cruise control electronic module requires that this circuit be intact, then just a bad bulb or poor electrical connection in the bulb socket might be the problem.
Hope this provides some help.
thanx again bud; preciate it
I am referring to the bulb in the instrument cluster, the one behind the green light in the upper right. I do not know if this will accomplish anything but it is the ONLY tie in to the headlight switch that I can see.
You said that the cruise control works when the headlights are off. It would be interesting to see if 1) it still works with the headlights off or 2) does not work at all when you remove the bulb. I suspect the latter.
The bulb is illuminated via the dimming module. The dimming module does its thing when the headlight switch is turned on. The bulb is "grounded" via the cruise control electronic module. This makes me want to guess that the cruise control electronics does an integrity check on this circuit and does not allow the cruise control to work if this circuit is not intact. In other words, the Japanese in their never ending quest to protect the driver against himself, may have decided if the light does not work then it is dangerous to use the cruise control.
If removing the bulb causes the cruise control to not work at all, then I think there is a high probability that you proved that the problem is in this circuit. If this occurs then make sure there is good contact between the bulb socket and the circuit board it mounts to. I would then replace the bulb just for good measure with a known good new one. It is also possible that the dimming module itself could be faulty (most likely).
Again, I have to emphasize that I am just guessing about this circuit but it is the only obvious tie in to the headlights. The troubleshooting I described above is a pain in the ass because you have to remove the instrument cluster to get to this bulb. However, If I had the symptoms you described (it works only with the headlights off), I would try this before I would pay the dealer to fix it.
They're now deleted!
I brought this back from the dead; because I haven't gotten this problem fixed yet. I'm not brave enough to venture into the electrical system (making sense of the diagrams you guys ahve provided me <--> not a techie when it comes to this electrical stuff) I was talking to a friend of mine and he said that this problem is definitly in the computer. I didn't know the car's computer had anything to do with teh cruise. But I was told to take it to the dealer and ahv the dealer do a diagnostic check on the computer and they'd be able to program/fix it right there. Does anyone know if this could be a possibility? And in addition to that; does anyone know how mcuh this could possibly cost???
thanx again guys...
thanx again guys...
Hi there all,
I just stumbled across this forum looking for a solution to my cruise control problem. Sounds similar to others. When I press the dash button to enable the CC, the light on the button illuminates, and when I set the CC from the steering wheel control the dash indicator illuminates, but that's all ... no CC functionality at all. This is on a 2001 CL-S and the dealer indicated that they could do an investigation, but that would be ~$250-300 and that would just be to tell me how much I'd have to pay to get it fixed ... a little steep for me :-( Any other ideas?
Question on Your cruise control Problem
Your post on here is a few years back but i was wondeing did you ever get this problem resolved? Have the same problem on my CL.
Originally Posted by Limmerz
97AcuraCL...
Same problem here....
It seems to have started after i did the whole LED conversion on the tails....
have had the "check brake bulb" light on, so i am assuming as one stated earlier in this thread, that the cruise control really doesn't work if all of the tail lights are not working all the way...
I put in 2 10ohm resistors in paralell for the turns, and didnt want to have to for the brake lights bec the resisitors get too hot, and im on the brakes a lot more than turn signals...
trying to think of another way...
hope this helped
hope this helped
I'm reviving this really old post, but i'm having cruise control issues as well.
I recently had my timing belt etc.. changed, and ever since my cruise control wont engage, all the lights come on as they should but it does not work
anyone have anything on this?
after youve checked all the fuses, reset your ecu. just disconnect the battery on the negative terminal and let it set for like 5 minutes. if that doesnt fly, take it apart. see if the little chain/loop dealy is snapped(not model specific, i havent taken apart the cc on this car). annnnd if that doesnt work, im really at a loss for suggestions. maybe check your throttle body, or see if you can pull some codes.
Originally Posted by artbran
They might have not connected the cc box back from changing he tbelt..
j series or F series?
Its a 1999 CL3.0
I believe its the J30A1 engine. Is it very hard to check the connection. I'm not much of an expert in this
wow what an old thread.
Sounds like the CC isn't hooked up
