Perfect Shift Point / Rev Limiter
Old Jan 13, 2004 | 08:08 AM
rmh3093's Avatar
Pass the dutchie!
I was reading in the archive and noticed somone calculated the optimal shif point in our car to be 7000 RPM however is the redline starts at 6250 and the rev limiter is at 6500....
did I understand everything correctly and is there a way to remove the rev limiter?
Old Jan 13, 2004 | 11:20 AM
red99cl2.3's Avatar
who got the best deal?
i dont think you can get that far without hitting the rev limiter and if you could it really woulnd be the ideal shifting point because there is no power that high.
red99cl2.3's Avatar
also are you sure that wasnts for a second generation?? cause i think they can rev up to 7200rpm so that woudl make more sense
Old Jan 13, 2004 | 04:27 PM
rmh3093's Avatar
Pass the dutchie!
thats not the right idea, the object is to have the least difference in torque between each shift, the lower the rpm the more torque and you only need torque to get the car moving so in the higher end of the rpm there is little torque so thats why you are supposed to shift near red line, letting the rpm drop before shifting will slow your car down
Old Jan 13, 2004 | 05:25 PM
red99cl2.3's Avatar
yeh but i meant up there as in 7000rpm since our car has no power!!!! up there, i;m more than positive he was talking about a second gen
Feb 25, 2020 09:57 AM
Sep 17, 2015 10:16 AM
Sep 14, 2015 10:09 PM
phillyguerrilla
Sep 11, 2015 06:39 PM
Mike Bertram
Sep 10, 2015 09:27 AM
