parking brake does not work. car rolls!!
Si says "shut the fuk up"
it worked before the winter time. now it doesnt work. i tighten the cables and pulled as hard as i could. it still doesnt not work. ( 5spd)
so my question....
what is my problem? do i need new cables or new rear calipers???
so my question....
i do park in gear all the time. my driveway has a slight hill and i dont like the sounds of my gears rubbing.
so, is it a cable problem or caliper problem?
thanks
thanks
its probaly both, especially for me. my ebrake problem fucked up my rear right brake assembly. my e-brake doesnt hold for shit in neutral anymore either. if you open your center console and take the fuzzy cover thing out of the way you can see how cockeyed the cables are.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by SupraManAG
ghetto ftw
Originally Posted by Mach30SiR
does the handle pull up with relative ease? if so you need to tighten the cable, otherwise its a caliper issue.
people on some other forum say i might need new pads for the rear. could this be a possible solution???
btw, i currently do use rubber stops under the front wheels to prevent from rolling away.
thanks
Originally Posted by starboy2nv
could be your calipers... is there tension on the cable?
before when my e-brake did work, the rear calipers would always stick to the rotors. i think that the prblem may be related......
nuldabz
09-03-2015 05:49 PM
