Park and Neutral
Old Jan 6, 2005 | 09:59 PM
DrDre1443's Avatar
112K and on 1st tranny!
Park and Neutral
I just got home from a little drive. I noticed a funny noise coming from the engine bay. It only happens when it is in park, and neutral. when in reverse and in gear, no problem. Sounds like something rotating and grinding/rubbing on something metal. like imagine one of those huge fan blades in the vent. system in the movies where the good guy has to pass through or get chopped to pieces.
any ideas?
Old Jan 6, 2005 | 10:15 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
is it a whining noise?
i have a whining noise like a bearing or maybe my waterpump going out
Old Jan 6, 2005 | 11:40 PM
Repo1234's Avatar
I think it might be the tranny! Mine did the same thing. Listen to it more carefully and you might notice that the noise is coming from the tranny.
Old Jan 7, 2005 | 12:14 AM
DrDre1443's Avatar
i'm not sure exactly where it is. I thought it was a fan until touched the blades and they were fine. If it has anything to do with the tranny, I would bet on the torque converter. when it gets cold at night, it takes forever to "lock in" when I'm driving home from work.
Old Jan 7, 2005 | 07:58 AM
wilp99's Avatar
thats because the fluid is cold. that slippage is the fluid not being pumped thru the servo's fast enough to lube the clutch plates. let the car warm up for bout 2-3 min before u drive when its cold out.
Old Jan 7, 2005 | 08:12 AM
CLpower's Avatar
teh Senior Instigator
mine does the same, I find when the car is warm it doesn't do it as much. I currently am changing tranny fluid on every other oil change. It's weird that we all have the same problems, we need a lawyer to talk to acura
Old Jan 7, 2005 | 08:44 AM
its not my tranny cause i just got mine fully rebuilt in july
i think its a tensioner bearing or the water pump according toa honda technician at honda
Old Jan 7, 2005 | 12:10 PM
Motohip's Avatar
I'm a llama :(
When my distributor was going out it made this grinding, squeeky noise. Took me forever to figure out what it was.
Old Jan 7, 2005 | 12:20 PM
DrDre1443's Avatar
well I'm having my timing belt, water pump, tensioner belt, all replaced on monday. We'll see if that fixes it.
Old Jan 7, 2005 | 01:10 PM
dragon084's Avatar
1999 CL3.0
any word on anyone testing out that Remote Transmision Filter?
:: does a search ::
SidhuSaaB
May 30, 2020 12:40 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
h22lude
Sep 27, 2015 06:22 PM
MikeJM310
Sep 24, 2015 07:24 PM
Brandle34
Sep 23, 2015 07:20 PM
