P1738, transmission code. HELP PLEASE.
Old Mar 11, 2011 | 08:11 AM
AnalyzeFaith's Avatar
Does the transmission need replacing? Or is this just a sensor or easy fix? Its the clutch 2 sensor. Here is a thread I found, my question is. I cant really see the part! So can someone find me the part online so I can order it? http://www./forums/showthread.php?p=478789
Old Mar 11, 2011 | 08:37 AM
Is it one of these parts? http://www.statracing.com/oem-replac...rt=AT+Solenoid
Old Mar 11, 2011 | 12:16 PM
asianspec's Avatar
please search next time. i found your answer here
https://acurazine.com/forums/1g-cl-problems-fixes-71/p1738-manufacturer-control-transmission-98-cl-3-0-a-699134/
Old Mar 11, 2011 | 12:52 PM
Actually... It didnt answer any of my questions and I've already read that thread like three times. Thanks anyways.
Old Mar 11, 2011 | 03:18 PM
P0401's Avatar
I would check the connector at the switch and if everything looks good there I would replace the 2nd clutch pressure switch. Everything I have read doesn't indicate there is anything wrong with the transmission itself just the switch or wiring to the switch
Old Nov 5, 2012 | 10:06 AM
jb1aze's Avatar
i'm having the same problem, would you know where the 2nd gear pressure switch is located?
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
2Quik
Sep 23, 2015 01:03 PM
