open door indicator issue
Old Jul 17, 2005 | 04:21 PM
ingsoc747's Avatar
Have a strange problem... when my drivers door is open, the indicator on the overhead view of the car on the speedometer dash does not light up.
What makes it weird is that all the lights on the little overhead map light up when i start up the car, so I know the bulbs are working. Second, when I press the little button on the inside of the door jamb, it makes the courteousy light go off, so I know that the switch is working!
What else could be wrong?
Old Jul 17, 2005 | 04:26 PM
Acura3.0CL's Avatar
DamnThisHobby'sExpensive!
Whoa...im totaly confused but it sounds like you have some definitly wiring issues...So let me get this straight:
When the door is open, the little door light on the instrument cluster dosnt light up, but when you start the car, the overhead map lights come on?
Old Jul 17, 2005 | 05:57 PM
ingsoc747's Avatar
what i meant by that is whenever you first start your car, most of the test lights come for like two seconds, then go off. all the lights in the car door indicators come on for a second, so all the bulbs are OK in that cluster.
Old Jul 17, 2005 | 08:35 PM
Leon's Avatar
did you check to see if that lil button is stuck?
Old Jul 17, 2005 | 08:55 PM
ingsoc747's Avatar
the button seems fine, it pops out when the door is open, and if i push it in, i can see the courteousy light near the bottom of the door go off, so i know that it is hooked up properly... unless these is some other wire or connection that goes to the main panel? anybody know?
Old Jul 17, 2005 | 09:37 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
I would bet there is more to that mechanism than just the switch that turns off the courtesy light. I'm not sure why this is happening, but it'll probably be expensive to find the cause and repair it, so I'd just learn to live with it.
Old Jul 17, 2005 | 09:49 PM
ingsoc747's Avatar
yeah guess im gonna have to
Old Jul 17, 2005 | 10:03 PM
03CoupeV6's Avatar
Unless you have the funds to spend on finding that problem?
Old Jul 18, 2005 | 07:04 AM
ingsoc747's Avatar
not really... saving up for a new audio setup atm
Old Jul 18, 2005 | 12:51 PM
dragon084's Avatar
1999 CL3.0
just make sure your dome light is set at OPEN so when ur door is open YOU KNOW ITS OPEN
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
tman570
Jun 11, 2019 07:56 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
brandnewcolony
Sep 12, 2015 10:39 AM
