Online Service Manual
I
i downloaded that online repair manual thingy, i forget the link, yoda something, and it gives me something as an ISO file.
what the hell do i use to read an ISO file?
Bagel Bomber
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Any CD burning software, you have to burn the images to cd's
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by SwervinCL
alcohol 120 is what I use.
Turtle Charged, Biotcch!!
I think you need to install the program (Mitchell on Demand??) first, then when you run it the first time, you need to update/import the database by inserting a different CD.... i removed it from my comp a long time ago so i forgot...
Oh and for the guys in Socal who want to have a copy but doesn't have cable/high bandwidth internet, just give me some cds and i'll make copies 4ya...
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by trupa
what's the address for the manual?
OK guys, bringing this one back from the dead because I am lost. I burned the image of the iso file onto a disk, it changed the file name to Mitchell. Now how do I open it?
Did I mess something up?
(Mid-Atlantic)
(Mid-Atlantic)
Install it, the iso should write files to a cd, then install it off the cd i think, or you can search the other manual pages and there's step by step instructions, I don't use it, i just host it, i have all 3 helms manuals in print
Agree with acuratl_2nr
Daemon tools will open this iso file and run it...I am not sure...but i think it runs it as if it were a new drive..can splain it...but it works great as long as you have enough disk space to keep the iso file.....for long term...burn it to cd............. try magic iso
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by acuratl_2nr
you don't need to burn it onto a cd, i just run the .iso file using Daemon Tools...
I really need a guide for replacing the right rear caliper assembly, and swapping the pads.
I've spent a couple of hours trying to figure out how to handle this ISO crap.
I tried burning to a disc, it doesn't help. It's just like having the ISO file on my cd instead of my computer. Not sure what I did wrong.
Daemon Tools says I don't have the correct OS, even though I do.
Help, someone!
Is it possible to send the whole thing as a zipped pdf or something?
I need to fix my car
Help, someone!
(Mid-Atlantic)
(Mid-Atlantic)
U need to use the ISO image to burn the file, on nero the option is burn image to disk, don't burn as a data disk cuz it will burn the iso data, not the image.
so i downloaded nero, burned two discs, tried to install it on my computer, and it just gives me errors.
when i go to setup, it has me put in information, then says something about registering, and then gives me a black screen.
every time.
i tried other exe files in the package, and they just give me pop up errors.
this is ridonkulous
OK so just after I posted this, I figured I'd try the HELP file. No help there, so I was like "screw it I'll just try the exe one last time before giving up"
sure enough, it magically started.
Excellent
every time.
this is ridonkulous
Excellent
(Mid-Atlantic)
(Mid-Atlantic)
