ONE dim headlight?? HELP?
7th Gear
Hi CL owners, and Happy Holidays, this is my first time posting so please bare with me.
I have a 1999 2.3 CL with a spoiler... recently i noticed that only my spoiler light works, but not my third brake light... checking further, it doesn't have another plug, so i spliced it in (and being i saw it posted i guessed it would work out fine!) BUT! heres the problem:
-My passenger side low beams are DIMMED [as dim as my high beams are for regular driving]
-and my driver side is fine... both lights are stock, so i thought it would be a 'soon to go' bulb, and i went and replaced it...
-BUT !! same problem... I'm fairly sure its not the low beam bulb.
-To make matters more complicating, when i turn on my high beams, my whole passenger side is dark, whereas my driver side is bright.
-I tried unplugging my spliced spolier/third brake light, but that didn't help.
-checked the fuses, and they seemed fine.
I was wondering if anyone else might've had this problem?? I know that the lights are originally dim, but in comparsion btwn my driver and passenger, its very very dim.
Any suggestions?
(ps, everything else electronically seems fine... battery is a year old, car is a 70k.)
help!
Any suggestions?
help!
Re: ONE dim headlight?? HELP?
Any suggestions?
help!
Any suggestions?
help!
7th Gear
cool, thanks a lot guys... i think i'll prolly disable one of the brake lights, but that comes last... I'm planning on trying to replace the high beam light, hopefully thats what's pulling the power and might be the reason that the high beams are totally dark.. ill get back to everyone after i try it out,
Thanks!
Thanks!
its paid for
as for the 4 brake lights in the back, just contact you local stat patrol and ask them, I've had all 4 and never had a problem. As for the headlight, see if the ground is good. This happened to me on my teg and it was due to a frieh connector (where the bulb and the wire come togther) I put a new connector on and it worked great.
7th Gear
hmm.. sounds interesting, thanks for the help, but howd u get a new connector? you cut your original off and tagged on a new one? yea my ground seems faulty, so ill prolly have to check that out too.
thanks
thanks
7th Gear
OK, got it fixed.. here was my problem (along with teh connector (THANX) my wire was becoming faulty... the reason being is that it was orginally cut by the previous owner and maybe water or high humidity caused teh wire to short... but not really bec AUSe it was still carrying a connection... SO, a waterproof wire was run to my driver side headlamp for collateral i guess.. and it worked out fine.. both my fuses burnt in the process but easy to find (engine bay) so NOW i have two working headlights! ah HA thanks all for the help. =)
soupi
14
11-15-2015 11:15 AM
