oil pressure?
oil pressure?
Any boosted f23s out there, what oil pressure readings are you seeing?
My gauge is reading 65psi @idle and 105@WOT. I think there is a wiring problem but want to make sure this isnt right before I tear back into it.
I did a custom dual gauge pod on the steering column but I cant post pics until tomorrow. Hate to keep everyone waiting.
No I was right in saying 65 and 105 psi. I think its just a bad gauge since a friend of mine has the same one and his does a full sweep before settling on 40 psi. Also when the car is in the on position it should be at 0 but my needle points to 40. Calling the manufacture Monday to see about getting a replacement.
Thanks for the info, hopefully I can work it out with Glow Shift tomorrow.
I know you cant see below about 20mph on the dash but who cares, I don't. This was also my first time playing with fiberglass which turned out to be a pain to work with. After a lot of time sanding and using filler to try and make everything smooth I discovered textured paint at Walmart. They only carry a few colors so I had to spray it black after the textured paint dried. I have to admit I am pleased with the results but would like to get some input from everyone.
Here are some pics of the install.
IBankMouse
06-13-2020 12:53 PM
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
