oil change
Old Feb 19, 2003 | 01:36 PM
damond's Avatar
oil change
I've been changing my own oil since my very first car and I've always replace the filter each time.
Are you actually required to change the filter each time, if you keep using the same weight and brand of oil? On my CL, I usually change it by every 4K mi, but no more than 4K.
Old Feb 19, 2003 | 01:56 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
The owners manual recommends changing the oil filter every 15K. This is the same manual that recommends changing your oil every 7.5K.
I change the oil filter with every oil change. I think the standard is to change the filter with every other oil change.
I base mine on the fact that I run Mobil 1 and change my oil and filter about every 5-7K. I get the "Double Guard" filter from Fram. So far this seems to work fine.
Old Feb 19, 2003 | 02:02 PM
Slooo97CL's Avatar
its too inexpensive to not change the filter everytime you change the oil. Whats the point of having fresh oil with a dirty filter?
Old Feb 19, 2003 | 02:10 PM
nandowong's Avatar
Work safe avatar bish :D
I dont mind paying 7-10 bucks for peace of mind, plus while you are down there you might as well do it.
Old Feb 19, 2003 | 02:23 PM
joeshmoe's Avatar
My Home Planet
I always change my filter when I change my oil. Around 5K miles using Mobil 1 synthetic.
Old Feb 19, 2003 | 02:35 PM
damond's Avatar
When did you Mobile 1 users start using M1? Mine has 67K on it. I currently use the regular Mobile oil....that stuff is as clear as cooking oil. Good stuff.
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
