Off The Strength..
Off The Strength..
i recently have had this "off the strength" occurance with my 99 3.0 .
its at a red light / stop sign. I am fully stopped. I slowly, when i say slowly, i mean slowly,
like millimeter by millimeter, let off the brake without hitting gas. When I am in the process
of coming off of the brake pedal, the car shakes. I find this odd. It almost feels as if
im an in a car with a manual trans and im letting off the clutch quickly. Not as severe a
shake, but it is there, and it is getting to me. I also have noticed that when my car is fully
stopped or parked and running, every accessory light besides the clock and climate control
blink very rapidly, can this have anything to do with the high beam conversion? The
blinking even occurs on my parking lights and courtesy lights
when my A/C is off and my stereo is off. I have a feeling if I get a Fuel Filter change, New
Plugs, and New Wires I might fix all of my problems.
- Please Give me some Advice
- What are good plugs? (heard that the platinums are not good, might go with ngk)
- What are good Wires? (have no knowledge on this)
- All Fuel Filters are typically the same, correct?
the light problem sounds like a definate alternator planning to go out soon like in a week or 2
the shaking i dont know about but i have the shakes a little too but that is from the balencing of the tires and i think mine are off
it could also be the tranny clutch packs enaging and having trouble catching and causing the car to shake some
How much does it shake?
also by replacing the wires and plugs would not help the shaking at all and the fuel fiter could be going out but not too sure you would probably have to have it checked out or clean the filter if you can
good plugs to get are denso iridiums, get about 1-2hp out of them and good wires are the magnacore wires but dont go too big i would say not bigger than a 10mm but i think a 9.5 is perfect
wire for a v6 will run you about 100 for the 4cyl about 80 and for the plugs i paid 13 a plug at a local tuner shop i think it was 96 for all the plugs for a v6
the system i have right now.
i got the top of the line sears battery. (the gold edition).
I got a re-built alternator.
Could my battery to alternator connection be coroded.
I feel like something is coroded somewhere along the line.
I also cannot wait to get my battery cap put on, it might put a damper on my problem
Product Specs
3 year full replacement limited warranty*, 100 month limited warranty*
Extra power for today's complex vehicles
Our best-selling DieHard
Designed for your climate
Maintenance free
See store for complete warranty details
Product Overview:
Item Weight 39.0 lbs.
Battery Type:
Overall Type Starting
Transportation Type Passenger car and light commercial
Battery Group Size 25
Temperate Zone North
Power Configuration:
Cell Type Lead-Acid
Number of Cells 6
Voltage 12.0
Design & Construction:
Terminal Post Location Top
Container Material Polypropylene
Dimensions:
Length 9-11/16 in.
Width 6-7/8 in.
Height 8-7/8 in.
Warranties & Coverage:
Months in Use Free Replacement 36
Months in Use Pro Rated Replacement 100
Product Specs
Maintenance free
Product Overview:
Battery Type:
Cell Type Lead-Acid
Number of Cells 6
Voltage 12.0
Dimensions:
Length 9-11/16 in.
Width 6-7/8 in.
Height 8-7/8 in.
the flickering is getting worse!
I feel like theres is a big problem with my car.
the shaking is getting more and more violent when i "creep" in the ack.
I'm scared that my alternator is gonna go again and that mycar might seriously be messed
up. Someone @ work said that maybe it has something to do with my brakes (the shakes).
I think the electric system of my car is faulty. Theres gotta be something going on from
the battery to alternator to the engine, somewhere along those lines. I think that my
alternator might be fine but theres some thing thats seriously worrying me. I'm
getting my power cap put in saturday, maybe this will help me.
I really hope the alternator isnt going out again.
What do you guys think is the problem here?
the shaking happens usually when i have less than a half a tank of gas.
no one else has had these shakes ?
please do. It sounds like a fuel problem if it only stutters at half a tank or less... maybe you fucked up your fuel pump with all that nitrous use. You do have nitrous don't you? I could swear I saw you purging in a pic once.
all i have ever done to my car is the following :
I.C.E
Woodgrain Steering
Gold Battery
Custom Grille
Conti-Sport Tires (the ones that come on benz's)
Shaved rear
Removed spoiler
mets liscense plate frame
clear bumper lights (amber now, clear sux)
9005 conv.
thats about it
I.C.E
Woodgrain Steering
Gold Battery
Custom Grille
Shaved rear
Removed spoiler
9005 conv.
thats about it
heading over to my station @ 330; its 2 15 right now. ill let cha'll know after my group meeting
tonight, I am psyched to have the new blue wires and fresh plugs. I am gonna have some body
work done and they will do the engine detail. I cant wait to see how pretty her brains gonna look.
to add to that im gonna have stanely steemer do the guts after i get my two-tone leather.
After the summer's over. Im gonna get wheels so that summer '05 i should have a show quality car.
PSYCHED FOR A FUEL FILTER THOUGH!!!!
you guys think that 500 was a lot for a steering wheel?
i payed 460 for a tune up.
wires/plugs/airfilter/fuelfilter/cap/rotor
I got the 150$ wires . they are KEM wires. yellow edition.
my car is a little more peppy. we will see what happens when i get below half a tank.
i think itlll go away cuz after i filled up (with 89 rather than 87) it shook very lightly, then went
away. I think its on its way into its glory days 49,8600 miles. Im lovin it baby, just lovin it
Type-S1
Jan 18, 2005 07:37 PM
