ODB2 TO ODB1 wiring for H22
busted
Questions
1-does the f23 fuelrail work on h22
2-does the f23 injectors work also the fuel pressure regulator swap-will it work to make plugs fit
3-distibuter plugs change over(2 clips on h22 and 1 on f23)
4-Map sensor is what color-I forgot
5- air intake bypass clip swap
6-the 4 plug white,blue,pink,and green wires at bottom of f23 block on timing belt side of motor is what? Thanks for any help this is becoming a mess for me
Acura604
20
08-05-2017 12:55 AM
SUPRMN84
10-07-2015 09:46 PM
