o2 sensor on cai... help
Old Nov 15, 2001 | 10:28 PM
cljosh's Avatar
sorry guys its probly been asked but i have searched the site and only found stuff on 2000 cls and i have a 97 2.2
i have a off brand cai in my room about to go on it only has 1 hole on it for the breather but where does the o2 sensor go....
does the aem come with holes for the breather and the o2 sensor
should i send it back and get the aem ...can you guys post some pics of ur cais thanks josh
Old Nov 15, 2001 | 11:34 PM
cljosh's Avatar
please
Old Nov 15, 2001 | 11:51 PM
Kiljaedoen's Avatar
the air intake has nothing to do with a o2 sensor.
o2 sensors are in the exhaust
on the intake you should have a hole for a hose from the valve cover breather and the only other thing you have to do is cap off a vacume line on your fire wall
here are some instructions for the installintake install
intake install
rip out all the stock crap. that means
1. the intake tube
2. the big resonator box in the bumper
3. the air box
4. the little shit thing connected under the stock intake tube
5. all parts that hooked up to that thing. a bunch of hoses and one electrical connector. that sytem is the A.I.R sytem and u dont need it. ull see that all those little hoses trun into one that goes up to the firewall.rip that hose off and cap that one line.
6. install aem intake
7. hook up hose from valve cover to aem intake
8. put air filter on intake and close up the wheel well
9. resest ur ecu. pull the fues in the box on the passenger side of car in engine bay or just discconnect battery. let it sit for awhile.
10. hook up battery or put fuse in
11. start car and let it warm up dotn give it any gas
thats it
Old Nov 16, 2001 | 02:08 AM
ilike2cheez's Avatar
i was just wondering when i installed my CAI i dint cap any vacum hoses. I dont see any to cap. i dont know wat u talking about when u say cap off the hose at the firewall. can u explain where i can find this hose. Now u make me wonder if i installed the CAI right. It seems to work ok. Pics will be a great help. Thanks in advance!!!
Old Nov 16, 2001 | 09:28 AM
cljosh's Avatar
people tell me if you dont have that sensor on the intake your car will run like krap
but do just unplug it
Old Nov 16, 2001 | 11:50 AM
Kiljaedoen's Avatar
YOU CANT TAKE OUT THE STOCK INTAKE HOSE CAUSE THERES A HOSE ATTACHED TO IT
its that line you cap off and unplug the electrical connector
i dont know how you took it off if you dident see the plug or the vacume line?
Old Nov 17, 2001 | 11:04 AM
VXCL's Avatar
AWD Torque Monster
my AIR system is rippe dout and disconnected. car runs better tyhen before the cai. that system i sfor the stock intake only.
Old Nov 17, 2001 | 06:14 PM
hmmm i dont see any electrical connecters...there was one line hooked up the the stock rubber intake hose( the main one) and it goes to the crank shaft and ppl tell me that a breather goes there. I just use the silicone hose ( that came with it)to connect the intake pipe to to the crank shaft. and the other hose that runs under it which is filed with like coolent to the the intake manifold ( i think its what is is since it runs to that thing with the factory shit on there) I dunno...i think i did it right. maybe i just overlooked something that i did. But i dont really see and electrical connecters!!
Old Nov 17, 2001 | 10:27 PM
Kiljaedoen's Avatar
there is deffientely
1 eletrical conector
1 vacume line
1 valve cover breather tube
Old Nov 18, 2001 | 03:19 AM
well last time i check there is an electrical connector but i dont have to disconnect it. Maybe its becuase u have a 2.2. and i have a 2.3. I guessing it might be different.
Old Jul 17, 2003 | 05:54 PM
ju5tchi11in's Avatar
roomate has a CL too
hmm oldie....
all I see is 2 hoses that are welded together so that one hose connects the stock intake to the engine... (valve cover/ engine?) and the other one connects two other components together.... I can't seem to get the second of those 2 off... is one of the components the AIR system for the stock intake? or is one the throttle body.
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
