O2 sensor
Old Jan 15, 2002 | 05:12 PM
BigBrother's Avatar
O2 sensor
i need to pull out my o2 sensor from my exhaust so i can install my headers, but unfortunantly i can't. does anybody have any bright ideas on how to remove it? if you do it will be much apreciated.
Old Jan 15, 2002 | 06:19 PM
niedejb's Avatar
Swaps? $3000 for 50HP? :(
Use an open end wrench and tap the wrench with a hammer till it breaks loose.
I havn't taken the primary one out but my secondary I had to remove for my bungless cat. I was able to muscle the sensor loose with a wrench but ended up smashing my left index finger into the body of the car doing so. Good luck.
Old Jan 15, 2002 | 06:50 PM
RidinLow's Avatar
Scooby Guru
I sprayed my WRX's O2 sensor bolt with penetrating lube & let it sit overnight... and it still was a bitch to get off. Just make sure you don't go crazy with the lube or touch the O2 sensor's probe with it!
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
