Is this normal (cruise Control)
When I hit the button it stays right at that speed. but when I hit the decell button and let go it usually drops a couple mph then goes back up to where I let it go. it also does the same when I hit the accell button it goes a couple mph over then goes back down to where I let go of the button
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
That's normal, it's because you let off the gas for the computer to take over. I've had it happen on other cars, but i've found that it recovers to around the speed i set it to, not exact of course. But it works
sometimes, but not 5-8 mph FIX: just keep your foot on the gas (cruise) until you feel that cruise control has taken over. This will prevent your car from decelerating during that gap of time between when you press your cruise control on, and when it actually sets.
(Mid-Atlantic)
(Mid-Atlantic)
You have a vacume leak in that mechanism. Mine does not decelorate as you described. Though, I had this problem with my integra. It was a leaking vacume hose that went to the cruise control unit. After replacing the bad hose, it worked like it should. This problem is not normal and should be examined.
A vacume tester guage. You attatch it to the line and check for the expected pressure. Each hose will have a specific expected pressure.
Good luck.
You can also hold a lit cigarette near the lines and look to see if the smoke is drawn to a particular area. This is a shade tree trick and should be used with common sense. Ie: don't hold the cigarette near you fuel lines or too close to the hoses.
Good luck.
Good luck.
Good luck.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
