Noise on accerlaration?
98 2.3CL
Well, I just picked up my 98 2.3 CL a few days ago. Anyway, I've started to hear a high pitched almost whiney sound. Thing is I only hear it when I barly push the gas. Like at cruising speeds. Not when I'm on the gas really hard. Kind of like in the middle. It's definitely coming from under the hood. Any idea what might be causing it?
Thnaks.
Thnaks.
Is it loud or quiet? My intake makes that noise now. At least I never noticed it until I installed my intake.
We have a Subaru outback '06 and it makes that noise also when you barely press on the gas. (and it doesn't have a modified intake)
98 2.3CL
It's not too loud. It's very high pitched though. Like you can only notice it with the a/c and radio off when driving. But yeah, my car is bone stock. I'm not sure what it is though. It seems to be running fine.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Do you have an aftermarket intake?
Bagel Bomber
I had the same problem look for a thread started by me maybe two months ago. Turned out to be a combo of water pump and idler pulley, this happened a few hundred miles after my timing belt service. fixed now though. I wouldn't suspect its your alt noise if you can hear it when the radio is off.
Bagel Bomber
i'm bored at work: http://www.acura-cl.com/forums/showthread.php?t=179621
poke around under the hood and tell us where you think the noise is comming from.
Bagel Bomber
Originally Posted by SwervinCL
You will get that noise if your timing belt was just changed. Kind of sounds like a supercharger. Its just the belt breaking in.
98 2.3CL
Thanks for the replies. Like I said, I only hear the noise when I have the gas pedal depressed about 20%. The sound is actually pretty dull but high pitched. My friend didn't even notice it until I rolled down the windows. We'll see.
Let me go pop the hood...
I actually just experienced this today on my way home for work. They way I'd describe the noise I heard was as if a a big semi was hitting the brakes and they were squealing. I have all the same symptoms listed above. I was basically stock at the time with just cat back exhaust, but I installed my AEM V2 when I got home so hopefully I'll never hear it again.
(Mid-Atlantic)
(Mid-Atlantic)
Check your vacuum lines
It is definitley the A/C bearing. I had the same prob. The dealer replaced the bearing when they changed my timing belt. The labour is gonna cost you $$$ but the part is about $70.00 cdn.
Bagel Bomber
ur as welcome as cancer
My car sounds like an old ass car, kind of a not rattling, but "i have to work hard" sound hahaha. I figure @ my milage, my engine's just dying.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
