! Noise !
Old Sep 20, 2004 | 12:05 AM
roddymerritt's Avatar
RODDYS
! Noise !
Ever sense I got my header on I have been hearing this noise. Its like peace of metal vibrating. Anyone else with a header have this problem?
Old Sep 20, 2004 | 09:41 AM
fusionnv's Avatar
Gimmie my points Biatch!
You have a lift or access to one? It might actually be a pieve of metal touching the exhaust pipe or one of the brackets holding the pipe is not tight enough.
Old Sep 20, 2004 | 12:17 PM
babyloc86's Avatar
specially on low rpm right? i had the same problem when i got my resonator installed. i took it back to the shop that installed it. he foudn out where the pipe was touching, hammer the thing that holds the resonator (some 2 rubber thing) and *BAM* it wuz fixed.
Old Sep 20, 2004 | 05:16 PM
97Acura3.0CL's Avatar
ENGAGE MY VTEC BABY!!!!!!
are you sure all your bolts for the headers are on all the way, it can be loose but you would hear air and it would be a little whistling and louder a bit
Old Sep 20, 2004 | 05:38 PM
jermz123's Avatar
check for cracks.. i had a crack on my obx's so i gotta wait til friday to get it fixed. check it out asap because taht crack can get real big quick
Old Sep 20, 2004 | 11:18 PM
RODDYS
I think its either what babyloc86 said of either its the heat sheild around my cat
Old Sep 20, 2004 | 11:26 PM
CLTECH's Avatar
Honda Technician
it's probably your heat shield hitting your exhaust pipe
Old Sep 20, 2004 | 11:32 PM
RODDYS
How do I fix it
I thought about getting a custom cat back with no reso and no catjust straight pipe
Old Sep 20, 2004 | 11:34 PM
CLTECH's Avatar
Honda Technician
to fix it, put the car on a lift, move the pipe around, and check to see what part of the heat shield is hitting the pipe. You can't miss the heat shield: it's the only shiny metal underneath your car. After that, then take a hammer to the shield and bend it away until it doesn't hit the pipe anymore.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
