nitrous plug ?'s
nitrous plug ?'s
ok, im going to be getting a zex nitrous kit in the near future and i have a few questions.
1. ive been told that i need to run the cooler nitrous plugs if i run the juice, but that i should not run the cooler plugs all the time as they arent good unless your running juice 24/7. so do i have to change plugs out to run nitrous and then put the regualr plugs in to get to work (for example)?
2. does the zex kit come with a unit that retards the timing when the shit kicks in? i understand that the timing heeds to be retardewd to run the juice correctly...
thanks all
thanks all
teh Senior Instigator
I ran cooler plugs all the time w/o issue, I just went to a 7 plug though, wasn't much colder, this is a must do though
the only way to retard our timing is to reprogram the ecu, a colder plug will be fine
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
xsilverhawkx
09-28-2015 06:51 PM
