NITROUS HELP! (Install)
Old Aug 11, 2003 | 01:07 PM
Luckyax2's Avatar
Evolution
Like I mentioned earlier I have a NX EFI kit, I pretty much understand everything, just need to figure out what to do with the Wide Open Throttle Sensor. How does this activate. Its not like Rick's Zex where its all electronic this is like a switch that activates. What can I do about this?
aaron
Old Aug 11, 2003 | 01:57 PM
CLpower's Avatar
teh Senior Instigator
do you have a picture? I'm not familiar w/ the NX kit
Old Aug 11, 2003 | 09:43 PM
Luckyax2's Avatar
Evolution
i could, i will try to upload tommorow
Old Aug 11, 2003 | 10:59 PM
d98clturbo's Avatar
Old Timer
you have to position the switch close to the throttle body next to the butterfly (the thing that the throttle cable is attached to) when the throttle is fully pressed (WOT) the thing will turn and touch the switch, activating it
Old Aug 12, 2003 | 09:34 AM
CLTECH's Avatar
Honda Technician
I think the EFI kit should have come with the electronic unit that measures how much voltage is running through the TPS wire....should be a small black box with an LED light on the side of it. Then again it could have come in the GEN-II upgrade kit, I dont remember. I think if you go to www.nitrousexpress.com there should be an install of a new civic and how to wire it correctly to the throttle body.
Old Aug 12, 2003 | 11:25 PM
Luckyax2's Avatar
Evolution
yeah I deffinitely dont have that Cl tech, what d98cl said sounds exactly right!
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
