NITROUS HELP! (Install)
Like I mentioned earlier I have a NX EFI kit, I pretty much understand everything, just need to figure out what to do with the Wide Open Throttle Sensor. How does this activate. Its not like Rick's Zex where its all electronic this is like a switch that activates. What can I do about this?
aaron
aaron
you have to position the switch close to the throttle body next to the butterfly (the thing that the throttle cable is attached to) when the throttle is fully pressed (WOT) the thing will turn and touch the switch, activating it
I think the EFI kit should have come with the electronic unit that measures how much voltage is running through the TPS wire....should be a small black box with an LED light on the side of it. Then again it could have come in the GEN-II upgrade kit, I dont remember. I think if you go to www.nitrousexpress.com there should be an install of a new civic and how to wire it correctly to the throttle body.
cycdaniel
12-17-2019 11:58 AM
pistacio
09-26-2015 10:45 AM
