Newbie Needs Help
Newbie Needs Help
I Just Picked Up A 98 Cl 2.3 Prem Last Weekend. Its In Pretty Good Shape@146k Miles. I'd Like To Tune It Up This Weekend And Would Like Some Suggestions On Brands, Etc.. For Bolt On Performance And Basic Stuff. Like I Said, Im New To The Scene And What Appreciate Any Info, Things To Look For, Ideas, Whatever.................thanks
Bagel Bomber
oil change - spark plugs (NGK) - Plug wires (NGK) - Distributor cap + rotor - coolant flush - Sea Foam the bitch (before oil change) - Air filter - Fuel Filter - PVC Valve.
I'm sure someone will think of other things you can do in a weekend.
Bagel Bomber
Originally Posted by biggkarim
Should I Stick With Oem Tune Up Parts Or Try E3, Accel Etc?
I Forgot To Mention Its An Automatic Trans.................thanks Again
As far as parts, i stick with OEM - NGK is oem for wires and plugs - You cant go wrong with geniune honda/acura parts from the dealer. it will charge you an arm and a leg, so do a quick google search for acura oem parts -- should be the first one taht comes up.
HERE ya go, did the work for ya - goodluck with everything
http://www.google.com/pagead/iclk?sa...gry1%3DINTEGRA
DunesCreations
09-09-2015 12:03 PM
n2booz
09-28-2004 05:35 PM
