New suspension parts
Ive swapped out nearly every suspension part on my entire car except for one last piece that I cant figure out what it is called. The car was wrecked on the right side and this piece was bent. It is in the front right of my car and is right next to the tie rods. Does anyone know where I can order this part if anywhere. And last is this part the same as on the honda accord 94-97. Ive searched around BTW even on google
Picture of part highlighted in Yellow
is the "radius rod" interchangable between the accord and the cl? do you know where i would even go about getting one?
edit: im assuming i would have to pull one of these parts from a junk yard car because i dont know any place that sells them
im guessing its from the 94-97 accord. thanks blaze i appreciate the help. this whole suspension nightmare is nearly over and my car is damn near completely restored minus the paint being fubar. i think i will be sleeping a lot better in the near future once i get this last thing (me knocking on wood) taken care of. that and the o2 sensor, and abs wheel speed sensor.
^^thanks for the info. ill call around to some junk yards to see if they will pull it out for me. im just too busy doing everything right now to spend a few hours at the junk yard. im not worried about the alignment since its aligned correctly right now but it pulls hard right because of the bent rod. and it feels like a grocery cart wheel when i make a hard right. im riding on 2 19's and 2 16's up front until i get it fixed.
thanks for the help everyone hopefully this will be the last suspension piece for a while that needs fixing.
Once you do it, it's a tight fit below the axle to get out the two bolts on the lower control arm. Just jack up the hub / wheel assembly while you do it, gives you a little more space, then it's just one nut in the front support of the car and out it slides. The front nut on the end of the rod is 32lb-ft, and the two bolts are 76lb-ft.
i just got some great news, i talked to a guy who totaled his 97 accord in the rear and will sell me his radius rod for $20. now all i got to do is try to talk him into taking the part off for me
glad you think so, i thought it would go great with the car
my rims are 4 lug, they just stopped production on them a few years ago. if do decide to keep the lip the way it is ill have to do a little finish work to make it look 100%. i guess i got tired of looking at the chrome every day wishing they were black instead.
http://images.google.com/images?q=st...-revision&cd=1
