New rims installed, question/problem with them
Old Mar 18, 2003 | 06:33 PM
ding069's Avatar
acura-cl.com OG
OK, i got the new rims on and first off, i love the looks and the ride/ handling qualities of the nitto 555's. They are a very smooth, not too loud tire, and awesome in the rain. I put the rims on myself, and at high speeds, i.e. 60-80mph, i was getting some serious vibration throughout the entire car, not just the steering wheel. Sounds easy, just high speed balancing right? So, i took them back to the tire shop, and they checked out the front tires and found that the balancing was off. So they rebalanced them and torqued the lugs in. The problem went away for about 20 hwy. miles, and now it is back, not as bad as it originally was though. The guys said come back if it got any better, and they will do them same to the rear tires. SO, i will prob have them looked at thursday. My question is, could this problem be from messing with the tire sizes from a 205 55 to a 225 40? Is it the balancing, or might i need an alignment also? I am sure a lot of you fanatics know more then me, so help me out. I cant deal with this vibration anymore, also, i dont want to hurt my brand new tires.
Old Mar 18, 2003 | 09:11 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
I doubt that your vibration came from the change in tire size. Have them double check the wheel balance, and the alignment.
I just had a thought: Did your rims come with spacers (plastic rings that fit over your hubs)? If so, check and see if they're on ok.
Old Mar 18, 2003 | 09:43 PM
suXor's Avatar
Still trolling
Also, have them make sure the wheel/tire isn't out of round.
Old Mar 18, 2003 | 10:00 PM
VXCL's Avatar
AWD Torque Monster
tire size doesnt matter. try switching the fronts and rears after u know thye are all balanced right. if prob is still there then somethin else is up. nitto 555s arent a symmetrical are they? that wouldn make them louder if they are on the wrong wheel, but it wouldn't cause vibration. if the prob only came about after changin ur rims and tires its obviously one of the 2.
Old Mar 18, 2003 | 10:10 PM
ding069's Avatar
acura-cl.com OG
Dust, i only opened one of the rim boxes and all they came with was center caps. If they came with spacers, they were not in that one box, or the shop didnt give them to me. They were also saying they are tough to balance because they only balance on one plane, which means on the inside lip. Can't they use the flat sticker weights on the outside? I dont know, maybe it could be an alignment problem? Could that be the culprit, did anyone need an alignment after this tire size jump? I dont believe ADR's come with spacers, anyone with ADR's chime in and help me out. Thanks for your help guys
Old Mar 18, 2003 | 10:12 PM
ding069's Avatar
acura-cl.com OG
Sorry for whoring. Chris, when you say out of round, what does that mean? Also, VXCL, what does symetrical mean, im assuming its the same thing as a directional tread?
Old Mar 18, 2003 | 10:18 PM
Yeah, check to make sure they have the directional tires going in the right direction. There should be an arrow on the side wall showing the direction.
Just a guess.
BTW: I have ADR's and no problems here. I have the flat sticker weights on the 7.5" wide, inside surface area.
rseb4agze
May 3, 2016 07:41 AM
bailey24
Nov 21, 2015 08:43 PM
lland
Oct 4, 2015 04:47 PM
asahrts
Sep 4, 2015 05:55 PM
nuldabz
Sep 3, 2015 05:49 PM
