New here..Security System question
Hi Guys,
This is such a great forum and friendly community and I am glad to be part of it.
I am about to buy a 1997 3.0 CL.
Black exterior. 88K.
The keyless entry system works fine (lock, unlock, trunk release etc).
I tested the security system but it is not working.
I armed it using remote and the light near the window starts blinking.
I opened it using the key with out disarming using the remote. It opened normally without sounding the alarm.
What might be wrong? is it a blown fuse?
Thanks.
John
Thanks.
John
blah blah blah
Originally Posted by johntheripper
Hi Guys,
Thanks.
John
Thanks.
John
The alarm is working fine because when you open it with the key it will not sound the alarm. If you want to test the alarm just set the alarm with the window down and open the door lock from inside without not key.
Thanks for the replies guys.
I had a Ford Taurus before![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Alarm on that car go off, if I tried to open the door by pressing the handle outside or if I try using a key without disarming it.
If I understand correctly,
In CL if someone uses a duplicate key or something, alarm wont go off.
If someone breaks the window then alarm wont go off.
If someone breaks the window on driver side, then press the silver unlock button, and then opens the door then alarm wont go off.
Seems pretty useless security system
DiamondJoeQuimby
09-10-2015 11:40 AM
