Need torque spec for brake bolts
Old Jun 11, 2006 | 08:40 PM
Racer510dude's Avatar
Im doing my brakes soon and need to know the torque spec. Anyone know the torque spec for the brake caliper holding bolts? I know the caliper mounting bolt is 80 ft lbs but forgot the torque for the two holding bolts.
Old Jun 11, 2006 | 08:53 PM
Here's my setup:
Front
Rear
Hawk HPS
Old Jun 12, 2006 | 06:35 AM
smoky14's Avatar
54 ft/lbs
Old Jun 12, 2006 | 10:17 AM
shineynitelite's Avatar
NAWWWWSSSSSS
thats 4 rears you got there
Old Jun 12, 2006 | 10:45 AM
54 ft lbs seems alittle off to me...I was thinking maybe around 30ft lbs.
No they are 2 front and 2 rear...not 4 rears. Fronts has 10 slots and rear has 8 slots.
Old Jun 12, 2006 | 11:06 AM
Woodsdaddy's Avatar
Everybody Wang Chung
If you are talking about the 2 bolts that hold the caliper to the caliper bracket they are 36lb-ft.
Old Jun 12, 2006 | 11:52 AM
thanks someone finally came up with the answer.
Old Jun 12, 2006 | 11:53 AM
Buddy4679's Avatar
The MAN....who else?
I have the same rotors...watch out for drag on the rears.
Old Jun 12, 2006 | 11:54 AM
what do you mean by "drag" on the rear?
Old Jun 12, 2006 | 12:03 PM
Buddy4679's Avatar
the pads never really come off of the rotor surface and you can hear them after I brake and even when I havent used the brakes in awhile. They dont get super hot or show excess wear, but you can still hear them as if they were still being applied.
Old Jun 12, 2006 | 12:08 PM
sounds like you have defective rear brake calipers to me... It was one of the acura cl recall.
Old Jun 12, 2006 | 12:09 PM
Buddy4679's Avatar
will it be covered if i did the brake upgrade myself? Will they say I damaged them?
Old Jun 12, 2006 | 12:10 PM
Buddy4679's Avatar
Will it be covered if I did the brake upgrade myself? Will they say I damaged them? I never noticed anything with the stock rotors of course, there is no way to hear anything on a smooth stock rotor.
Old Jun 12, 2006 | 12:12 PM
I don't think it will be covered because you used aftermarket parts which voids the warranty.
Old Jun 12, 2006 | 12:13 PM
Buddy4679's Avatar
I can simply put the stocks back on....its just the rear rotors that have the recall correct?
Old Jun 12, 2006 | 12:14 PM
yes you can do that.
Old Jun 12, 2006 | 12:15 PM
Buddy4679's Avatar
PM me, I hate hijacking threads.....sorry dude!
Old Jun 12, 2006 | 12:16 PM
it's ok...i got the answer i needed.
Old Jun 12, 2006 | 02:51 PM
NAWWWWSSSSSS
those are 4 rears dude..
Old Jun 12, 2006 | 05:47 PM
SupraManAG's Avatar
One custom CL
i know what u mean shiney
i really think those are interchangable because of the 2 lil screws that hold the rotors in place
Old Jun 12, 2006 | 05:53 PM
NAWWWWSSSSSS
does 98 + 99 have the hub over rotor design like the 97s?
if they do, then these are clearly wrong
Old Jun 12, 2006 | 06:16 PM
SupraManAG's Avatar
One custom CL
true true
Old Jun 12, 2006 | 08:15 PM
No... 97 are different from 98 and 99. BTW i know these are the correct one for my 99 cl.
Besides hub over rotors design are a pain in the ass to remove. You would need an impact wrench to remove that damn hub nut, as for 98 and 99 its two simple screws that hold the rotors onto the hub.
Old Jun 12, 2006 | 11:56 PM
NAWWWWSSSSSS
simple depending on where you live...
i had to pound on mine, then sit there with a torch for 10 minutes each screw then they finally came out
Old Jun 13, 2006 | 12:22 AM
lol... I remember sitting in front of my rotors from dusk till dawn just to drill that bastard out. Screw drivers just strip those damn screws and make it almost impossible to screw out without a drill. I got pissed so i didn't put those screws back in, works great without them and changing rotors is a peice of cake. Wish i had an impact wrench at that time.
Old Jun 13, 2006 | 12:40 AM
NAWWWWSSSSSS
you have to use a screw driver..
1. sit w/ torch for 10 minutes
2. put screw driver in the screws and then pound on the back of the screw w/ a big ass hammer
3. unscrew
if 3 doesnt work repeat again lol
god hondas a bunch of dick heads when it comes to accord brakes
Yikes
May 3, 2021 04:29 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
