Need info on my clutch
My clutch all the sudden this morning got real loose and engaged earlier than normal is there any sugg. out there as to what it may be, anything will be appreciated.
hope you're sitting down....
your clutch is toast. happened to me few weeks ago. get it checked out soon before it engages literally while its still on the floor (like happened to me). the guy said my clutch had shattered and was in several pieces (woohoo) good luck, not a major repair, maybe a good oppurtunity to upgrade.
his problem is eather the clutch master cylinder(least likley) or the slave cylinder (most likley) usually they can be rebuilt, autozone sells kits for them they cost like 15$ but u have to bleed the system. which is just like bleeding a brake. i would start there since thats alot cheaper than getting the clutch replaced, but if that doesent fix it then its definatly the pressure plate.
Trailblazer = SUCK
My clutch went out on my CL the clutch pedal u press it on it stays on the floor and i need to grab it and pull it out i just finished buying the master cylinder and the smaller one is it easy to install do i need to move something to get there
Trailblazer = SUCK
or lack therof...
how handsome I am
WRONG
jesus christ the same thing happened to me not months ago. Leaky Master/slave clutch cylinder. buy the parts online and get them installed... its a bit expensive, but it needs to be done.
Also, my mechanics told me I was only leaking out of the slave, but I replaced both just incase... you dont want 1 part going bad, replacing it, then the other going soon after it.
-Alex
-Alex
how handsome I am
oh yea:
HOLY OLD THREAD BATMAN
(always wanted to say that
-Alex
Teh HORN!@!!!
that happened to me with my eclipse....When you replace the master slave cylinder, make sure you replace the slave also at the same time or else one or the other will fail.......feel the floor by where your clutch pedal is and see if its wet, if it is then ur master cylinder went out.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
