Need Help Removing Heated Seat Buttons
I got my heated seat indicator bulbs from the dealer this weekend but can't seem to pry the switches out to get them in.
The only thing I see is the small slot in the back of the switch to insert a small screwdriver.
I took out the ashtray to get a better angle but I still can't see how to get them to pop out of there without chewing up all the plastic around the slot.
Is there a little trick or do I need to remove something else to get to them?
Thanks for any help
Thanks for any help
Jamie,
They should just pry up with a small, flathead screwdriver.
If they won't come up when prying in the "slotted" area, see if you can get the blade in on the opposite side of the switch.
I would put a thin, but tough piece of cloth under the blade of the screwdriver, just to avoid scratching/scraping the plasitc when prying.
Good luck!
Good luck!
Maybe I'm being too careful with it....I didn't want to make it worse than it was when the dealer took them out and chewed up the drivers side a little.
And now that it's 85 out I really need to get these fixed
Need help removing the radio/center console? Check out this site.
http://carstereohelp.com/stereoremovalHondaAccord2a.htm
Re: Need Help Removing Heated Seat Buttons
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
rockyboy
Jan 25, 2016 06:00 PM
