need help now
sorry i have no time to search but im trying to set up my new deck in my car and there is no audio no popping nothing but when i put stock deck in i put in code everything works... i think its security how do i bypasss it or make it work....
just use the "power antenna/amp turn on" and use it to connect to the stock amp turn on. or bypass the speaker wires from your stock amp, just go straight from the input to the output.
Well, if it's just 1 speaker, and it worked before, something is off with the wiring, or one of the wires isn't making contact perhaps it came loose after you taped it up?
do you have stock speakers? one of mine blew when i swapped my head unit. remember there 10+ year old speakers.. and not the best quality. after checking the wiring, keep in mind its very possibly you could have a blown speaker.
The cones are paper, and can blow very easily after putting in a new hu, but if you're getting no sound, I would bet the wiring is incomplete
