need help on installing aem cai on 97 2.2cl
What can I get ya?
It should fit no problem, are you sure you have the right product? Try putting on the filter after you have the intake tube installed or try turning the tube a little bit to get a different angle.
A-CL Post Whore w/N2O
If it's a true CAI, then yes, the filter will fit down in the wheel well area (sorta under the car).
Turn your wheels to one side. You'll need to gain access under the car (wheel well area) in order to stick the filter in. Then connect it to the end of the CAI.
I've not put one in a 2.2/2.3, but in the 3.0 you have to remove some of the plastic clips in order to peel back the wheel well enough to fit the filter in. Then attach it to the CAI pipe.
Click on the link in my signature, and look for my CAI. This should give you an idea of how the CAI filter looks, once installed.
Originally posted by STLUSMCH
do i need to have it up on a jack and i just bought the cai today where do i put the bypass valve
The bypass valve goes in the middle of the pipe.
Someone just posted a pic of their CAI. I'll look for it, and poste it here.
AWD Torque Monster
the filter goes in ur wheel well. and to use a bypass u have to cut a peice of tubing out. dont use the bypass unless ur gonna drive trough 1 ft deep puddles. i had mine for 2 years and drive through the rain all the time. my car is also dropped about 1.5"
Here's a pic of Casper's CL with bypass valve: http://images.fotki.com/v1/free/3a2d.../CL-CAI-or.jpg.
It's installed, right at the bend.
thanks for the advice but nobody answered ? about the difference in power will it
BoricuaTL
04-08-2016 01:08 PM
InFaMouSLink
10-27-2015 06:51 PM
Abe_Froman
09-16-2015 01:27 PM
