need help on install
Old Mar 15, 2003 | 06:54 PM
bryanz3.0cl's Avatar
nothing
what color is the TPS wot wire? and why is my zex smartbox flashing red?
Old Mar 15, 2003 | 08:38 PM
nothing
dust- which wire did you splice into for the tps wot wire, im hoping it was the red one?
Old Mar 15, 2003 | 08:42 PM
dustbuster4's Avatar
A-CL Post Whore w/N2O
red/black
Old Mar 15, 2003 | 08:45 PM
Your box is flashing because it needs to "read" your WOT curve. There should be directions on how to do this. It involves turning on the engine power without starting the car. I think you hold the accelerator to the floor for 10 secs until the Management unit "learns" the electrical impulse comming from your TPS.
Let me find my directions.
EDIT: Go here: http://www.zex.com/support/
If you're putting in the dry kit, look on page 5 of the "Dry Kit, .PDF Format:"
If you're putting in a wet kit, look on page 6 & 7 of the "Wet Kit, .PDF Format:"
Good luck!
Old Mar 16, 2003 | 01:12 AM
nothing
thanks dust...
ive had this zex kit since about november and i finally had time to install it, it was pretty straight forward but having no directions or a helms manual was a pain in the ass. luckily my brother knew what he was doing.
Old Mar 16, 2003 | 07:36 PM
dajuice27's Avatar
In Da LBC with Snoop Dogg
so bryanz, we will be seeing you at the track once you install this kit right?
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
