need help on install
A-CL Post Whore w/N2O
Your box is flashing because it needs to "read" your WOT curve. There should be directions on how to do this. It involves turning on the engine power without starting the car. I think you hold the accelerator to the floor for 10 secs until the Management unit "learns" the electrical impulse comming from your TPS.
Let me find my directions.
EDIT: Go here: http://www.zex.com/support/
If you're putting in the dry kit, look on page 5 of the "Dry Kit, .PDF Format:"
If you're putting in a wet kit, look on page 6 & 7 of the "Wet Kit, .PDF Format:"
Good luck!
Good luck!
nothing
thanks dust...
ive had this zex kit since about november and i finally had time to install it, it was pretty straight forward but having no directions or a helms manual was a pain in the ass. luckily my brother knew what he was doing.
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
